I have jpeg image. I want to create icon using that image. The icon I will be using for sub menus
There's actually a field called ICONmaxWidth you can use, that could change the size.
There is an ICON selection field when you create new Menu items, and it accepts Media entity, so just use your Jpeg image to create a Media would work.
Hi @zyuan1
Thanks for your reply.
I had tried using the media entity. But the icon size for menu is showing as very small as attached
But I am expecting the icon size as attached
