I am having troubles creating Infotable objects using the Thingworx Extension SDK. I have tried multiple methods and no seem to work.
Using From JSON
I tried to use the fromJSON method but i didnt work.
JSONObject jsonObj = new JSONObject("{\"dataShape\":{\"fieldDefinitions\":{\"id\":{\"name\":\"id\",\"description\":\"id\",\"baseType\":\"STRING\",\"ordinal\":0,\"alias\":\"_0\",\"aspects\":{}}}},\"rows\":[{\"_0\":\"178498585\",\"_1\":1531849323285,\"_2\":true},{\"_0\":\"178496396\",\"_1\":1531849187726,\"_2\":false},{\"_0\":\"178482871\",\"_1\":1531848400119,\"_2\":true}]}"); InfoTable it = InfoTable.fromJSON(jsonObj);
Building From Scratch
I have tried to build the InfoTable from scratch but no methods work.
1) Create Field Definition and using addField
InfoTable myIF = new InfoTable(); FieldDefinition Field1 = new FieldDefinition("Field1", BaseTypes.INTEGER); myIF.addField(Field1);
2) Create DataShapeDefinition -> Add field to that definition -> use infotable constructor with the data shape definition as input. I have also tried to use BaseTypes.String.
DataShapeDefinition dsd = new DataShapeDefinition(); dsd.addFieldDefinition(new FieldDefinition("MockedField", "STRING")); //also tried dsd.addFieldDefinition(new FieldDefinition("MockedField", BaseTypes.STRING)); InfoTable it = new InfoTable(dsd);
What is the correct way to create the InfoTable Object?
Thanks!
Hi @bwinslow24 you'll need to invoke the InfoTableFunctions class to create an Infotable, I've created a sample ThingTemplate below which contains a Property called "InfotableAsProperty" and a service called "CreateInfoTable" which also creates an infotable, and finally a datashape which is used in both Infotables
@ThingworxBaseTemplateDefinition(name = "GenericThing") @ThingworxPropertyDefinitions(properties = { @ThingworxPropertyDefinition(name = "InfotableAsProperty", description = "", category = "", baseType = "INFOTABLE", isLocalOnly = false, aspects = { "isPersistent:true", "dataChangeType:VALUE", "isEntityDataShape:true", "dataShape:CustomDataShape" }) }) public class CustomInfoTableExtension extends Thing { private static Logger _logger = LogUtilities.getInstance().getApplicationLogger(CustomInfoTableExtension.class); /** * */ private static final long serialVersionUID = 1L; /** * */ public CustomInfoTableExtension() { // TODO Auto-generated constructor stub } /* * CreateInfoTable service creates an infotable. */ @ThingworxServiceDefinition(name = "CreateInfoTable", description = "Creates an infotable", category = "", isAllowOverride = false, aspects = { "isAsync:false" }) @ThingworxServiceResult(name = "Result", description = "", baseType = "NOTHING", aspects = {}) public void CreateInfoTable() throws Exception { _logger.trace("Entering Service: CreateInfoTable"); InfoTable myIF = new InfoTable(); FieldDefinition Field1 = new FieldDefinition("Field1", BaseTypes.INTEGER); FieldDefinition Field2 = new FieldDefinition("Field2", BaseTypes.STRING); myIF.addField(Field1); myIF.addField(Field2); TagCollection mytag = null; EntityServices es = new EntityServices(); try { es.CreateDataShape("CustomDataShape", "Created from the extension sdk", mytag, myIF); } catch (Exception e) { _logger.error("Failed to create datashape" + es.getName()); e.printStackTrace(); } InfoTableFunctions myImf = new InfoTableFunctions(); try { myImf.CreateInfoTableFromDataShape("Infotable1", "CustomDataShape"); // creates infotable from a datashape. } catch (Exception e) { _logger.error("Failed to create Infotable" + myImf.getName()); e.printStackTrace(); } _logger.trace("Exiting Service: CreateInfoTable"); } }
Hi @supandey,
Thanks for the response, but its not exactly what I'm looking for. I should have explained a little better in my question. I am trying to mock the output of QueryBooleanPropertyHistory so I can test parts of my code with JUNIT. The output is an InfoTable. I want to build an InfoTable object and use that in my tests. I can instantiate the InfoTable object but when I try to add any fields or rows it doesn't work.
Brandon
