Hi
I have a requirement to perform the following operations on remote (child) TW servers from a (parent) TW server. Am planning to use ContentLoaderFunctions (PostJSON) from parent TW server to invoke a REST API call of remote TW server (Thingworx/Resources/EntityServices/ServiceDefinitions/CreateUser) with Appkey.
Please suggest me if there is any other better approach.
if we are creating the user with the help snippet, then we can use Resources["EntityServices"].CreateUser(params);. we can execute the same in remote server?
Appreciate your early response
Just create a Service on your Child server that you then invoke from the parent server - still contentloader, but much safer because you can add validation and restrictions in your Service (wrapper)
You could make that easier by adding Thingworx federation then it would be invoked over the wss pipe
You could also add something like an MQTT type interaction, now your parent drops the info on the queue and it is picked up by the child to then be executed.
Hi @nmohammed.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for participating in our community!
Regards.
--Sharon
