Create Username and password for organization
shreekant
6-Contributor
I want to create an login page for my organization and login using username and password.
I have followed the instructions at http://support.ptc.com/cs/help/thingworx_hc/thingworx_6.5_hc/index.jspx?id=FormLoginPagesforOrganizations&action=show
I have been able to create a Login page but what username and password should I use for successful login?
The link above descibed as
#8.Type your Name and Password.
But I am not sure which username and password to enter.
Please Help.
shreekant
shreekant
6-Contributor
(To:mgoel)
Thanks for your reply. I have been able to login with the guidelines https://developer.thingworx.com/en/resources/guides/data-model-security-control
but still I am facing a problem that the mashup is not able to load though it is present there.
I am getting error as Could not load "MyMashup". Reason: 404 - Entity Not Found : [MyMashup]
I have assigned a mashup to the user which I am using for login.
8 REPLIES 8
Hi Shreekant,
You need to use login details of the User, available under the organization,for which you created this Form Login page.
Drop screenshot for detailed help.
mgoel
(To:shreekant)
@shreekant
Thank you for your post on community. Have you created any user under organization in ThingWorx? If yes then you can login with that.
While creating user you should have assign a password to that. Please check it or change it if do not remember.
For custom pages you can try below article:
https://www.ptc.com/en/support/article?n=CS236678
Do let me know in case of any question.
shreekant
6-Contributor
(To:mgoel)
Shreekant,
You need to provide visibility permissions to that particular Mashup(home).
Once you open Mashup,on Left pane side--> Visibility (under permissions).
shreekant
6-Contributor
(To:TanmeyTWX)
Hi TNTWX,
Thanks for your reply. As you suggested the error dissapeared now but I am still not able to see the Mashup.
I am getting blank screen.
shreekant
Hi Shreekant,
Please apply same permissions to Mashup and User under Organization as well Mashup permissions.
Note: whenever you get to see partial display,make sure you have supplied the required permissions(Visibility/Design/Runtime) to the Entities(User/Mashup/Services).
attach your mashup here,if you are still not able to figure out the issue.
shreekant
6-Contributor
(To:TanmeyTWX)
Thanks for your reply. How to attach Mashup here!
shreekant
mgoel
(To:shreekant)
@shreekant
You can take take screenshots of opening permissions tab or you can take export or entity and attach here.
