Created An widget Extension with ( jdk11.0.13version ) and imported in composer. its showing successfully imported.
In mashup widget panel->>ALL->>imported(0).
IDK why??
please help me out this
see the attachments given below..
hi,
thank you for your time,
as you mentioned step3 : i found that i develop that widget in Eclipse "enterprise java & web developers" but it can't work in this env.
so i tried that another eclipse "java developers package "so its working on that. IDK why ???
In screenshot(14) can you select the extension at the top and make a new screenshot? In the bottom it should show your widget in "Package Details"
- If there is a widget shown: Did you refresh Composer after the extension was imported (like it prompts you after import)?
- If there is no widget: There is something wrong with your eclipse project
hi,
