Creo View and Thing View Widget Documentation to view 3D Object in custom mashup/UI.
RahulSoniVolvo
Please provide Creo View and Thing View Widget Documentation or guide to view 3D Object in custom mashup/UI except for the ThingWorx Navigate app.
Hello.
I wanted to clarify here; are you using Navigate? Wasn't sure if I understood.
Thank you,
-- Craig A.
RahulSoniVolvo
(To:CRArko)
I used Navigate to integrate to Windchill but I want to use ThingView and Creo View widget to view 3D in a newly created mashup.
hselarka
(To:RahulSoniVolvo)
Hi @RahulSoniVolvo,
Unfortunately currently you can use CreoView and ThingView widgets only for OTB Navigate. It can't be used / supported for any custom mashups.
Due to this reason we don't have any documentation also. Please refer to article CS291582.
Let me know if there are any further questions.
BR,
Harsh
RahulSoniVolvo
(To:hselarka)
Hi Harsh,
Thank you for your information!
That article was created after my discussion with PTC Technical Support. I was the part of the discussion for the article.
I posted this request to community. Not for this ThingWorx developers portal after discussing it with ptc technical support.
But this is happened and I have no option to to do move to community again.
The post Creo View and Thing View Widget Documentation to view 3D Object in custom mashup/UI. was moved by LeighPTC.
Many thanks,
Rahul
Hi Community Team,
Could you move this request to community. So that PTC Customer can have Creo View and Thing View Widget Documentation to view 3D Object in custom mashup/UI. As it is not available.
Many thanks,
Rahul
