Custom Authenticator - get User object in order to set User Extenstions properties
jacekgra
Hi, I am working on custom authenticator and I would like to store some auth key (from external system) in given user extension property directly in Authenticator code.
In normal service I can use following code:
User user = (User) EntityUtilities.findEntity("Jacek", RelationshipTypes.ThingworxRelationshipTypes.User);
user.setPropertyValue("lastName", new StringPrimitive("Gralak"));
And this works great. However when I am using the same piece of code after fire of successful login event in authenticator User object is null (EntityUtiilites are not able to retrieve user object):
AuthenticationUtilities.validateEnabledThingworxUser(USERNAME);
this.setCredentials(USERNAME);
AuthenticationUtilities.getSecurityMonitorThing().fireSuccessfulLoginEvent(USERNAME,SharedConstants.EMPTY_STRING);
User user = (User) EntityUtilities.findEntity(USERNAME, RelationshipTypes.ThingworxRelationshipTypes.User);
user.setPropertyValue("lastName", new StringPrimitive("authentiocator"));
Here user object is null.
Any hints?
I'm running into this same error.  Any luck on figuring it out?
A_Macierzynski
(To:jacekgra)
According to the doc validateEnabledThingworxUser method is deprecated (in 8.1). Maybe you can try to use validateThingworxUser.
I figured this out.  You need to give the User a Context.  Try this:
            // Start Transaction
            TransactionFactory.beginTransactionRequired();
            ThreadLocalContext.setSecurityContext(SecurityContext.createSuperUserContext());
            // Get User
            User user = (User) EntityUtilities.findEntity(userName, ThingworxRelationshipTypes.User);
            // Set User Property
            user.setPropertyValue("lastName", new StringPrimitive("authenticator"));
            // End Transaction
            TransactionFactory.endTransactionRequired();
I'm not sure if this needs to be in a transaction, but this works for me.  You'll need to wrap everything in a try/catch.  I have this code in a method that is called after the fireSuccessfulLoginEvent is fired.  Hope this helps you.
