Hi. I created some custom events that i need to use in my entity, so i wanted to know if there is a way i can add my custom events to the data window in the mashup builder? Check the image and thank you for your time.
I Want to add it where the red rectangle is.
Not on this side, what kind of events you need?
Hi, Carles, thank you for your time. What i need is to call the "ShowMessage" service of the Message Widget after a custom event triggers.
But which will be the root cause of the Event Trigger? I mean, in order to get a Event Triggered by the service first you have to call the service, and then you will get a ServiceInvokeComplete and you can act on this one. If you want that server does "push" an event when something happens, that's a totally different mater, and you can approach it with "Push Properties" look at this feature on version 7.X, basically when Thing's properties changes you get and update on the Mashup side, you should leverage GetProperties service on that case.
Carles.
