Custom Font on Mashup
mikei
Is there any way to change the font that is used on buttons, labels, etc.?  The style definitions certainly do not seem to expose that, so I was wondering if it were possible or if I will instead need to create some extension that allows that type of change.
Thanks!
Mike Intravaia
3 REPLIES 3
mhollenbach
(To:mikei)
Hello Mike,
No there is no way of modifying the actual font being used. You would have to create an extension that uses CSS to modify the way you want your widget to look.
Meghan Hollenbach
bitentf
11-Garnet
(To:mikei)
Mike, you can now use the Font Labeling extension: ThingWorx IoT Marketplace » Font Labeling
Tiago
Hi Tiago Bitencourt,
I am using Font labeling Widget but i can't able upload ttf fonts using Media entity. Is there any solution?
Sathishkumar C.
