Hi Guys,
I am using custom chart widgets and I have issue with timeseries chart.
From normal timeseries chart I am used to set my YAxis fixed, i.e. 0 min 100 max. (YAxisAutoscale off).
At custom TSCh looks like this
but no matter what I do (check, it uncheck it), set Ymax to 50 even though that my data are exceeding this value.
It always looks the same, is changes the Yaxis to fit the data..
What am I missing? Thanks a lot. Another issue is that label is not showing the Date portion of datetime..
I'm not sure how much help I could be without seeing the source code, but are you sure you aren't setting the auto scale property somewhere in the custom code?
Sorry Marked the answer as correct. Done that by mistake.
There is NO source code. I am merely referring to Custom Chart Widgets (https://marketplace.thingworx.com/Items/Custom%20Chart%20Widgets).
Used as they are...
Can someone confirm this bahavior?
