Custom Timeseries chart does not respect AutoScale off option
tcoufal
Hi Guys,
I am using custom chart widgets and I have issue with timeseries chart.
From normal timeseries chart I am used to set my YAxis fixed, i.e. 0 min 100 max. (YAxisAutoscale off).
At custom TSCh looks like this
but no matter what I do (check, it uncheck it), set Ymax to 50 even though that my data are exceeding this value.
It always looks the same, is changes the Yaxis to fit the data..
What am I missing? Thanks a lot. Another issue is that label is not showing the Date portion of datetime..
ttielebein
(To:tcoufal)
I'm not sure how much help I could be without seeing the source code, but are you sure you aren't setting the auto scale property somewhere in the custom code?
tcoufal
(To:ttielebein)
Sorry Marked the answer as correct. Done that by mistake.
There is NO source code. I am merely referring to Custom Chart Widgets (https://marketplace.thingworx.com/Items/Custom%20Chart%20Widgets).
Used as they are...
Can someone confirm this bahavior?
