Custom Widget 3rd-party Libraries
enze
So far I have manage to create a chat widget.
I was thinking of using socket.io to do so but somehow I am not able to use the library.
Yes, I have already look through several resources before opening this topic but none of this has helped.
I am getting an error known as "mismatched anonymus define() module".
Any help on this would be great, thanks!
https://community.ptc.com/t5/IoT-Tech-Tips/Widget-Extensions-Using-AAGRID-a-JS-library/td-p/535060
https://community.ptc.com/t5/ThingWorx-Developers/How-can-I-reference-my-js-libraries-in-custom-extension-widget/td-p/522357
bmihaiciuc
(To:enze)
This is because socket.io doesn't work with the require and define methods from the Thingworx 8.5 runtime.
One of the possible workarounds for this is documented in the Thingworx 8.5 release notes (at the end of the document).
An alternative might be to include socket.io using npm and webpack via this extension project.
However you can also work with web sockets on the client side without any other library through the WebSocket API.
4 REPLIES 4
smainente
(To:enze)
What is the exact version of your Platform ? Is it 8.5.0 ?
enze
(To:smainente)
Hi, yes it is.
I am using the trial foundation where I download and it could be used for 90 days.
My company already has the software but in order to work at home, I have to use the trial version.
But anyway, I tried to import the library using cdn of FileResources / renderHTML/ AfterRender(appending to body). All of this method did not work.
Thanks!
bmihaiciuc
(To:enze)
enze
(To:bmihaiciuc)
Hi, thanks so much for the reply!
I am using the one from Widget Extension(npm) and it works great, I was able to require the package and run it! The only problem I have with this is that I am not sure how to put in Thingworx Template / Service / Property. Do I code it the same way as how I did with Eclipse?
Will try the one from Thingworx 8.5 release notes  and let anyone who is looking for a solution using Eclipse SDK know if it is working.
Thanks so much for the help!
Enze.
