I am looking for an open source code for an rich text editor, as the HTMLTextArea widget is removed by PTC after Thingworx 9.0.
Can someone help me with this, I am looking for something like this.
Sharen
Thanks for the quick responses, @bchaudhary @VladimirRosu.
@VladimirRosu, as you suggested, we created a custom widget based on quills js lib.
https://quilljs.com/
Hello @SS_12358633
As I can see the Rich text has been removed due to security reason. To achieve your use case you need to create a custom extension . Please refer following article to assist you further
https://www.ptc.com/en/support/article/CS388313?source=search
https://www.ptc.com/en/support/article/CS201191?source=search
Hello @SS_12358633,
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Hi @SS_12358633 ,
Hi Sharen,
You need to create a custom widget based on a rich text javascript library - I see tinymce as an example.
There's nothing I observed based on a quick search.
