3-Newcomer
Jan 24, 2025 4:36 AM UTC
Custom Widget for Rich Text
I am looking for an open source code for an rich text editor, as the HTMLTextArea widget is removed by PTC after Thingworx 9.0.
Can someone help me with this, I am l
ooking for something like this.
Sharen
pshashipreetham
Feb 3, 2025 4:18 PM UTC
Thanks for the quick responses, @bchaudhary_448008  @VladimirRosu_116627.
@VladimirRosu_116627, as you suggested, we created a custom widget based on quills js lib.
https://quilljs.com/
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
Jan 24, 2025 5:17 PM UTC
Hello @SS_12358633
As I can see the Rich text has been removed due to security reason. To achieve your use case you need to create a custom extension . Please refer following article to assist you further
https://www.ptc.com/en/support/article/CS388313?source=search
https://www.ptc.com/en/support/article/CS201191?source=search
Emeritus
Jan 31, 2025 4:46 AM UTC
Hello @SS_12358633,
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Feb 3, 2025 2:14 PM UTC
Hi @SS_12358633 ,
Hi Sharen,
You need to create a custom widget based on a rich text javascript library - I see tinymce as an example.
There's nothing I observed based on a quick search.
pshashipreetham
