Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Custom Widget not displaying in runtime
pyekula
I am new in creating custom widget, following are the steps are did,
- Used Eclipse thingworx plugin.
- Added default HelloWorld widget and build it using gravel.
- Imported the extension project into platform.
I was able view it in IDE (check ide.png). But not able to view same widget in runtime(check runtime.png), not sure what I missed.
Would like to what I have missed as soon as possible
Aanjan
9-Granite
(To:pyekula)
Penchalaiah, it now works fine on a new Mashup? If you come across this issue again, try clearing your browser cache (or view the Mashup in an incognito/ private browser window) and retry.
ttielebein
(To:pyekula)
Are you sure the check box under properties for "IsVisible" is checked?
Yep. Not sure what happened, suddenly the custom widget start to appear after trying it new mashup
Aanjan
9-Granite
(To:pyekula)
