i'm trying to creating widget on line chart using polymer & sdk web component utility.
while doing that, i have imported required links into file.
after importing and using the component, getting error "moment.js is required before ptcs-datepicker import"
To resolve this issue, i have installed moment js via npm. still it is showing same error
can anyone help me on this ??
We have an internal case on this that indicates it was fixed in 9.3 version of the web component library. Which version are you running?
--Sharon
yes, we are using 9.3 version only
@slangley , any idea about this error, it's been long time, we are not about to solve it.
Hi @Rajkumar_20673.
Were you able to resolve this issue? Based on another post from your colleague, Shashi, is it possible you had omitted the extension on the filename?
--Sharon
