Custom widget debug not working
amejia1
6-Contributor
I try to debug my custom widget with the lines like this:
TW.log.warn('Test....');
but this aren't displayed anywhere (navigateur console or thingworx log mashup). Someone knows what's going on?
Version TW used : 7.4
Thanks.
drichter
(To:amejia1)
Have you try TW.log.debug instead TW.log.warn?
6 REPLIES 6
drichter
(To:amejia1)
Do you try this logging stuff in your *.ide.js or in *.runtime.js?
I can only see logs for *.runtime.js. Add your widget to an mashup, view this mashup and click on "Show/Hide Log".
amejia1
6-Contributor
(To:drichter)
Hello David,
In the .runtime.js
I did do that but nothing is displayed.
drichter
(To:amejia1)
amejia1
6-Contributor
(To:drichter)
Hello David,
Using TW.log.debug is OK when i click on "Show/Hide Log", however i can't see the log using the console tab in developer tools. For now it's fine for me.
Thanks.
rk-31
1-Newbie
(To:amejia1)
You can also try debugging with console.log('text'); in runtime.js file.
And check console tab in developer tools.
amejia1
6-Contributor
(To:rk-31)
console.log('text') doesn't work.
