18-Opal
January 10, 2018
Custom widget "Hello, World!" Issue
  • January 10, 2018
  • 2 replies
  • 5434 views
hi, i'm practice custom widget
TW.IDE.Widgets.helloWorld = function () {
  this.widgetIconUrl = function() {
      return  "../Common/extensions/HelloWorld_ExtensionPackage/ui/helloWorld/helloWorld.ide.png";
  this.widgetProperties = function () {
    return {
      "name": "Hello, World!",
      "description": "An example widget.",
      "category": ['Common'],
      "properties": {
      "Salutation": {
          "baseType": "STRING",
          "defaultValue": "Hello, World!",
          "isBindingTarget": true
        "TextSize":{
        "baseType":"NUMBER",
        "defaultValue":22,
        "isBindingTarget":true
  this.renderHtml = function () {
    return "<div class=\"widget-content widget-helloWorld\">" +
             "<span style=font-size: "+ this.getProperty("TextSize") +"px;>" + this.getProperty("Salutation") + "</span>" +
           "</div>";
  this.afterSetProperty = function (name, value) {
    return true;
  this.widgetEvents = function () {
      return {
          'Updated': {}
Hello, World We tried to construct a user widget that adjusts the font size by moving the slider using the example.(29 line)
However, the font size does not change.
The content inside is also unchanged.
How do I show the values that are bound in the widget?
seonho Cha​: Please confirm if this issue is still open and need suggestions.
-Durgesh
CHASEONHO18-OpalAuthor
18-Opal
January 29, 2018
Hi, Durgesh Patel
I am trying to create reactive text.
We're still trying it now.
thank
Hello, could you make it works in IDE (Composer) ?
You can try with pure html to be sure that the css works.
Then in ThingWorx, on run time, can you see the css set in source code ?
18-Opal
February 1, 2018
ide and rue time have the same css.
  1. .salutation {
  2.   font-family: Impact, monospace;
  3.   font-size: text-size // <- it defined properties in ide.js
  4.   text-transform: uppercase;
