Custom widget - the svg html element is replaced with i ?
seanccc
I'm using the 3rd party js ui libaray to create the custom widget .  But the the <svg> element in the original ui libary become <i> and the sub dom is not rendered in cusom widget .   Is there any magic rendering occurs when rendering customer widget ?
------The  html of the original ui library-----
---the html after rendering in customer widget---
@VladimirRosu ,
Yes, everything is fine, I just inspected different elements.
6 REPLIES 6
seanccc
(To:seanccc)
Sorry, my mistake .  I compared two different element.
PEHOWE
(To:seanccc)
@seanccc ,
Hope you are doing well. From review of the images you provided. It looks like you are using inline SVG markup, which according to the help center is not supported.
https://support.ptc.com/help/arbortext/r8.0.0.0/en/index.html#page/editor/editor_help/help6229.html
Hope that helps,
Peter
VladimirRosu
(To:PEHOWE)
@seanccc I presume everything's fine and that was just an issue caused by inspecting different elements, right?
@VladimirRosu ,
slangley
(To:seanccc)
Hi @seanccc.
Since you discovered the cause of the issue, could you please mark your post containing the solution as the Accepted Solution for the benefit of others on the community?
We appreciated your participation!
--Sharon
slangley
(To:seanccc)
Hi @seanccc.
I have marked the Accepted Solution for this topic.  If you disagree with my selection, please let me know and I will be happy to change/remove it.
--Sharon
