Customizing XY Chart widget
- August 22, 2019
- 1 reply
- 2116 views
Hi all,
I want to customize the XY Chart in ThingWorx such that the x-axis is on the top of the chart and the intersection with the y-axis is in the top left corner instead of the bottom left corner. The x-axis values should increase from left to right and the y-axis values should increase from top to bottom.
To do so, I tried to create my own XY chart widget to mimic the built in XY chart widget so that I do not overwrite the existing built-in XY chart widget. I have the necessary code of the built-in XY chart widget so I just needed to create another widget via Eclipse, copy and paste the code and import it to ThingWorx. The import is successful but I get an error when loading the mashup saying "XYChartV2Mashup opened with errors" so the widget doesn't get imported at all. I have attached the zip file containing the necessary files, it would be great if someone can help me find out why my widget isn't imported or suggest another solution to my problem.
