D3 Tree and Network widgets issue
tcoufal
Hi Guys,
I have some issues with D3 widgets for Network and Tree.
No matter what I do, I cant just see anything after my Mashups loaded. Original Tree widget works just fine.
I made a simple network with one root element and 10 nodes.
I am running TW 7.1.0
There is no video tutorial or any other document for new D3 widgets, as far as I can tell.
Can somebody provide me with some screenshots how the widgets need to be setted up.
Thanks.
Tomas
7 REPLIES 7
PaiChung
22-Sapphire I
(To:tcoufal)
Just tested this and both D3 work fine
Make sure you have Labelfield, To and From properly assigned.
to verify, you can split your layout and place a regular Tree widget next to it and wire it up the same way to verify.
ankigupta
(To:tcoufal)
Hi Tomas,
I too tested D3 tree and it worked fine on my ThingWorx 7.2.1 Instance.
Can you share the exact steps you are following and I can try the same on my Instance.
Basically we need to follow the same steps shared for original Tree widget and it should work.
Ankit Gupta
tcoufal
(To:ankigupta)
Hi Ankit,
here are the screenshots. It should pretty self explanatory.
ankigupta
(To:tcoufal)
Hi Tomas,
Everything seems fine. Same steps works on my instance.
Screenshot from my instance.
Any error in logs?
Ankit Gupta
tcoufal
(To:ankigupta)
No errors, none in the console, nor in Application logs.
Any other suggestion?
Should I restart the Tomcat after D3 extensions were added? Should I remove them and add them again??
T.
PaiChung
22-Sapphire I
(To:tcoufal)
You probably already tried CRTL + F5 for a full browser/widget reload right?
tcoufal
(To:tcoufal)
Yep,
deleting the extensions and putting them back on helped...
