May 20, 2024 9:20 AM UTC
DPM Production Dashboard
In DPM production Dashboard, we have a production accounting section inside that it is showing a delay of around 2 hours is it normal?
Please check system time and production accounting time
Rocko
RockoAnswer
May 21, 2024 8:39 AM UTC
This is time-zone related. The AC-Cellassembly is probably located in Germany, The "Date and Time" you see is the machine time, so everyone sees the same screen independent from where you consume the mashup.
Rocko
Rocko19-TanzaniteAnswer
May 22, 2024 12:13 PM UTC
Hello Rocko,
Thanks for the response could you please share how to change workunit timezone.
Atharva
Rocko
May 22, 2024 12:22 PM UTC
I guess you can't, the timezone is defined on site level and can't be updated. Create a new site with the proper timezone and equipment associated to that site.
https://support.ptc.com/help/digital_performance_management/r9.5/en/#page/dpm/digital_performance_management/equipment_list_administration/site_configuration_tab.html
Emeritus
May 27, 2024 2:30 PM UTC
Hello @Pratik_Aswale,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution. Or if you found a solution on your own, please document it in your topic and mark it as accepted solution. This will surely help other users who have similar questions.
Community Moderation Team.
