Data export widget does not like nested infotables
Willie
I've noticed that the data export widget outputs the parent infotable when I bind it to a nested infotable.  Is the data export widget only meant to work with non-nested infotables?
I wrote a separate service that outputs a non-nested infotable.
3 REPLIES 3
PaiChung
22-Sapphire I
(To:Willie)
Probably would be my answer based on your observation.
One thing you could do is just use services to generate your own CSV file into a file repository which you can then download.
slangley
23-Emerald II
(To:Willie)
Hi @Willie.
If you're satisfied with the solution you found, please mark your last post as the Accepted Solution for the benefit of others with the same question.  If you still have questions, please let us know.
We appreciate your participation in our community!
--Sharon
