Hi I have connected to HomeLight0 as in tutorials still I an not getting the values on mashup. What can be possible errors?
How do you have the service bound? Is it to a grid widget? I am not familiar with this tutorial, but if you send a screenshot of the widgets and their data bindings, I may be able to spot some issue.
Gaurav, what tutorial are you following? Are you getting any errors on your Mashup or is it blank?
Hi Ravi I am using the tutorial given on thingworx website to connect to Raspberry pi. Followed all the steps but I am not getting any properties for HomeLight0
@Ravi Anjan , Per my understanding he is Following the http://developer.thingworx.com/guides/thingworx-raspberry-pi-quickstart to connect raspberry PI to Thingworx Server.
Gaurav Kathale , are you getting the values in Properties of your HomeLight0 ?
Please provide some more visual inputs or on mashup itself you can see log or debug info else go directly in TW monitoring
You are not getting values of Properties on HomeLight0 on thingworx , are you sure your Edge and HomeLight0 are connected ?
If its connected , then have you done the bindings ?
If its not connected then there could be several reasons for that . Please attach screenshots of the console where you are getting connected to ThingWorx Server.
I think this would make me sure that I'm connected
Hey Gaurav,
What tutorial are you doing? And did you connect a service to the widget in the Mashup? Are you able to show a screen shot of your Mashup?
