Data on mashup not being loaded
gkathale
Hi I have connected to HomeLight0 as in tutorials still I an not getting the values on mashup. What can be possible errors?
9 REPLIES 9
ttielebein
(To:gkathale)
How do you have the service bound? Is it to a grid widget? I am not familiar with this tutorial, but if you send a screenshot of the widgets and their data bindings, I may be able to spot some issue.
Aanjan
(To:gkathale)
Gaurav, what tutorial are you following? Are you getting any errors on your Mashup or is it blank?
gkathale
(To:Aanjan)
Hi Ravi I am using the tutorial given on thingworx website to connect to Raspberry pi. Followed all the steps but I am not getting any properties for HomeLight0
rupadhyay
(To:gkathale)
@Ravi Anjan , Per my understanding he  is Following the http://developer.thingworx.com/guides/thingworx-raspberry-pi-quickstart  to connect raspberry PI to Thingworx Server.
Gaurav Kathale​ , are you getting the values in Properties of your HomeLight0 ?
nkhose
(To:gkathale)
Please provide some more visual inputs  or on mashup itself you can see log or debug info else go directly in TW monitoring
rupadhyay
(To:gkathale)
You are not getting values of Properties on HomeLight0 on thingworx , are you sure your Edge and HomeLight0 are connected ?
If its connected , then have you  done the bindings ?
If its not connected then there could be several reasons for that . Please attach screenshots of the console where you are getting  connected to ThingWorx Server.
I think this would make me sure that I'm connected
Hey Gaurav,
What tutorial are you doing? And did you connect a service to the widget in the Mashup? Are you able to show a screen shot of your Mashup?
