Is there any way to customize excel file(download) as per user need ?
As of now it only creates file with the name as "Export+DateTime".xlsx
Is there a way I could use a custom name like "BoilerData.xlsx" ?
TIA.
Tarun
Not OOTB, some browser settings can be changed to allow 'Save As' that is user driven.
You could create a custom export widget potentially
You could create your own export Server Side to a File Repository and name it and then execute a download link.
