DataTable import
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
DataTable import
While importing datatable iam getting this error- "Task-1626848130807 Data Import FAILED for [DataTable] [XXX_Datatable]. Entity does not exist".
How to handle it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I beleive you are trying to import Data from a Data Table for which the entity structure does not exist in ThingWorx. If you want to import Data for DT, you should first import that DT as an entity in ThingWorx. Export the Data Table entity from another ThingWorx and import and then try to import Data for that Data Table.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
