As per this thread- same issue:
Hi @PaiChung
I am doing the exact same exercise. I've already changed the property aspect to Always. Still my property values do not update. Is this a permissions issue? Do I need to do something differently?
Many Thanks
Just to give some context, the exercise I am doing is on a ThingWorx server.
I have values coming from MQTT and it updates the JSON. I have written a service that takes JSON values and passes them to the respective thing property. A subscription calls this service. The values on the property are not still updating. Even after I gave run time permissions to the system user. I've also got a persistent provider, are there any changes that I need to make on this?
Is there something I am overlooking ?
Any suggestions is much appreciated.
Hi all,
I found the problem.
It was in the subscription.
The correct code for the subscription is in the image below.
