When result = new Date() is executed, the result Time format is in IST, but as per the customer point of view it should be in UTC, how can it be done ?
Note: the output of the service should be DATETIME
@paic @slangley @c_lowy
Shashi
Since no solution is avaliable for this, using third party API's for Time is the easiest way.
In the Below Code used the CDT timezone, similarly it can be changed to the UTC.
var params = {
proxyScheme: 'http' /* STRING */,
headers: {"Accept-Encoding":"gzip, deflate, br","Accept":"*/*","Content-Type": "application/json"},
ignoreSSLErrors: true,
url: "http://worldtimeapi.org/api/timezone/America/Chicago" /* STRING */,
// result: JSON
var CDTdate = Resources["ContentLoaderFunctions"].GetJSON(params);
//date = CDTdate.datetime;
date = ((CDTdate.datetime).split("T")[0]);
time = ((CDTdate.datetime).split("T")[1]);
timestamp = ((time).split(".")[0]);
hours = timestamp.split(":")[0];
if(hours > 12 ){
result = date + " " + timestamp + " PM CDT";
else{
result = date + " " + timestamp + " AM CDT";
Shashi.
Google search shows there should be a Date.UTC available in javascript
See Article here
var params = {
// result: JSON
if(hours > 12 ){
else{
Shashi.
