Date in UTC
pshashipreetham
18-Opal
Date in UTC
When result =  new Date() is executed, the result Time format is in IST, but as per the customer point of view it should be in UTC, how can it be done ?
Note: the output of the service should be DATETIME
@paic @slangley @c_lowy
Shashi
Shashi Preetham,
Email: psp316r@outlook.com,
Mobile: +91 8099838001.
Since no solution is avaliable for this, using third party API's for Time is the easiest way.
In the Below Code used the CDT timezone, similarly it can be changed to the UTC.
var params = {
    proxyScheme: 'http' /* STRING */,
    headers: {"Accept-Encoding":"gzip, deflate, br","Accept":"*/*","Content-Type": "application/json"},
    ignoreSSLErrors: true,
	url: "http://worldtimeapi.org/api/timezone/America/Chicago" /* STRING */,
// result: JSON
var CDTdate = Resources["ContentLoaderFunctions"].GetJSON(params);
//date = CDTdate.datetime;
date = ((CDTdate.datetime).split("T")[0]);
time = ((CDTdate.datetime).split("T")[1]);
timestamp = ((time).split(".")[0]);
hours = timestamp.split(":")[0];
if(hours > 12 ){
    result = date + " " + timestamp + " PM  CDT";
else{
    result = date + " " + timestamp + " AM  CDT";
Shashi.
Shashi Preetham,
Google search shows there should be a Date.UTC available in javascript
See Article here
Hi @PaiChung ,
Sorry that didn't help ... !
Shashi
Shashi Preetham,
var params = {
// result: JSON
if(hours > 12 ){
else{
Shashi.
Shashi Preetham,
