Delete DataTable entries
praveenp
Looking for service to delete DataTable entries with specific column matched values
Ex : delete ExampleDataTable where columnX ="some value"
Tried  which is deleting all the records. This is expected.
When I try to use DeleteDataTableEntries from DataTable > Services , getting the message 'Must have a datashape defined to add rows...'  .  Created the DataTable on data shape only but still getting the message.
Hi Praveen,
I was just testing a similar service that deletes DataTable entries based on the value of one or more collumns. In my scenario, I have a data table with a Username (primary key), email address and subscription date. When a user executes this service, he or she will be deleted from a subscription list. I used only two collumns out of three to delete the entry but I am sure it works only with the primary key.
I used the service
DeleteDataTableEntry,
and my code looks something like this:
var values = Things["BlogSubscribersTable"].CreateValues();
values.EmailAddress = Resources["CurrentSessionInfo"].GetCurrentUser().emailAddress; //STRING
values.UserName = Resources["CurrentSessionInfo"].GetCurrentUser(); //USERNAME
var params = {
values: values /* INFOTABLE*/
// no return
Things["BlogSubscribersTable"].DeleteDataTableEntry(params);
kirans
(To:praveenp)
It worked with out primary key, now able to delete DataTable entries with specific column matched values
var values = Things["ClientName_Alerts"].CreateValues(); values.ClusterName = ClusterName; //STRING var params = {     values: values /* INFOTABLE*/ }; me.DeleteDataTableEntries(params);
