Delete entities and its dependent
svisveswaraiya
I have a Thing which has multiple datashapes in it. Is it possible that if I delete the Thing all its dependent datashapes should get deleted. Is it possible to do so?
Thanks in advance,
Shalini V.
I don't know any Out of the Box service to do this in Thingworx.
You can create your own service to do that; first get the dependent datashapes with GetImplementedShapes(), and after that delete them.
Hope it helps,
Raluca Edu
3 REPLIES 3
Hope it helps,
Raluca Edu
slangley
(To:svisveswaraiya)
Hi @svisveswaraiya.
If Raluca's response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
Hi @svisveswaraiya
I just wanted to follow up with you to see if Raluca's response was helpful for your question? If yes, please mark it as the Accepted Solution for the benefit of others with the same question.
Thanks & Regards,
Vibhuti
