I have Created a MASHUP which has an GRID Widget which contains the data as shown in below figure:
How Can I Delete the GRID Row on the Button "Delete" is pressed.
Thanks !!
Got the Simple Solution,
1. Make Sure the Thing BaseTemplate is DataTable
2. Such that we can find lot of Services DeleteDataTableEntries, DeleteDataTableEntry and DeleteDataTableEntriesByKey.
3. For me the Row in the Grid got deleted for all the three services.
4. Create a Checkbox Column in the GRID and make it "Editable" and put the default value as False.
The Grid's Edited Table is the INPUT for the following Service
for (var i= 0;i<EditedTable.length;i++)
var row = EditedTable.rows[i];
if(row.CheckBox ===true)
var values = me.CreateValues();
values.Column1 = row.Column1;
values.Column2 = row.Column2;
values.Column3 = row.Column3;
values.Column4 = row.Column4;
var params1={
values:values
Things["DataTable_Name"].DeleteDataTableEntry(params1);
Hi @SP_9715784
Thank you for opening this thread on community. Are you using infotable to populate data on grid?
Check this thread if it helps:
regards,
Mohit
Check this also:
https://community.ptc.com/t5/ThingWorx-Developers/Add-row-or-delete-rows-from-Grid/m-p/705129#M49724
Mohit
var params1={
values:values
Hi @SP_9715784.
Glad you found a solution!
For the benefit of others in the community, please mark your last post as the Accepted Solution.
Regards.
--Sharon
