Deleting Entries from Value Stream
giladl
I have a Value stream attached to a thing (the thing template...).
I would like to know how to delete rows of data from the stream so it won't over-stack :)
The perfect/optimal condition for me will be to delete properties history by timestamp.
Thank you with much appreciation,
Gil
paic
(To:giladl)
Hi Gil,
there is a PurgeStreamEntries Service.
You must specify a Property and Date Range for it I believe.
Generally for any of our Data Stores within Thingworx, look for Services that either start with Delete or Purge for those types of actions.
giladl
(To:giladl)
It's works,
Thank you for the quick response.
Gil.
VladimirRosu
(To:giladl)
It's interesting because it seems the ValueStream only allows null-ing the property values...not the rows themselves as the service PurgeStreamEntries from a normal Stream.
The service itself is called PurgePropertyHistory, not PurgeStreamEntries, showing this behaviour.COuldn't find a way to actually delete rows from a ValueStream.
paic
(To:VladimirRosu)
Did you purge each Property from the Stream and you still saw the rows Vladimir? i.e. just timestamp with no entries?
