Deleting a Data Shape
johnbuc
I have tried to delete a data shape, but cannot as Composer posts an error message that says this entity is referenced by one other entity.
When I review the dependencies, there are none listed.
How can I determine what entity is being referenced?  Could a mashup be the culprit?
Any help is appreciated.
John
paic
(To:johnbuc)
Hi John, this is a great place to use SQUEAL!
Go to your Squeal page: <server name:port>/Thingworx/Squeal
Search for your DataShape name (or part of it), click it in the search results screen and you should see where your item is being used.
johnbuc
(To:paic)
Thanks for the prompt response.
Good suggestion on SQUEAL.  I used it and the results do not show any other references besides a model tag.
Any additional thoughts or am I missing something here?
paic
(To:johnbuc)
Hi John, can you Restart Tomcat and then try the delete please?
Thanks.
johnbuc
(To:paic)
I restarted Tomcat and relaunched Composer.  I was then able to successfully delete the Shapes and Thingtemplates that no longer had any dependencies.
Thanks for the help!
