Detect mobile device
jgabriel
Is there any way to detect from TW global js, if the mashup is loaded from mobile device? I would like adjust widgets I made to fit on mobile based on this option, probably can be done by measuring viewport in jQuery, but is there any internal variable I can access?
Regards Jan.
BrunoD
9-Granite
(To:jgabriel)
Hello Jan,
In order to set the viewport parameter for rendering mashups on mobile displays, you need to use an extension.
Please follow this link to find an exemple of extension adding viewport parameter:
MobileHeader Extension
Bruno
BrunoD
9-Granite
(To:jgabriel)
Hello Jan,
Bruno
jgabriel
(To:BrunoD)
Yes I did almost the same extension: GitHub - Foxoncz/tw-metawidget-ext
