Different Widget Colour Schemes When Changing Selected Language
MP_10287512
Our ThingWorx solution has been facing an issue where, upon changing the Language of the solution, the Charts and Graphs have their styling options changed. I have attached two different pictures that more accurately portray this issue: it is the exact same graph with the only difference being the selected language.
What could be causing this issue?
1 REPLY 1
Hello @MP_10287512 ,
I have tried reproducing (TWX 9.3.1 ) the same use case on my end and it seems to be working as expected.
Could you pls share the sample entities that you are using?
Also the ThingWorx version and share the steps that you are following.
Bhawna
