I am trying to make a specific row in drop down menu as unselectable. All the other records in the widget should be selectable except for one row.
Similarly, a specific row in advanced grid should be unselectable.However, all the other records should be selectable.
Using row format property, I was able to change the styles of particular row. I have attached screenshot for reference in which CSP Packaging is grayed out but I also want to disable its selection.Any lead on this is appreciable.
MishiK
You may want to look into custom java extensibility and modify the widget on your own.
