We are starting with ThingWorx and we need to know what can be done with this software and how to do it. I would like to know more about the use of labels and label templates. I have tried to create and use it and I think it is useful to search and find entities in the composer. But I would like to know more about the use of tags in a runtime context. Do you have any examples of how the tags and model tags could be used in such a context? Could they be associated with a user/user groups...etc.
Not sure if you went through the online classes
here is the help entry on tags
Basically adding meta data to either a Thingworx entity or to Thingworx data
With that you can then do searches on those tags.
one other main use is Entity tagging for export since export supports grouping by tag although in more recent versions Projects was introduced.
