Display Images from repository based on selected items List
Ziyad
8-Gravel
Hello everybody
I'm trying to upload images that figures in my repository in order to visualise them in a mashup,
First I created a simple service for this that return image link based on selected items in a list which are Strings (E1,E2,E3,....) but I figured out that it's not that simple because I can not bind the image doesn't change in my mashup.
Actually I need to visualise images that exists in my repository but I don't find the file.
Now I don't understand why I don't get the image from my file
1 ACCEPTED SOLUTION
PaiChung
22-Sapphire I
(To:Ziyad)
GetFileListingWithLinks should get you the link to the image files in your repository
the Image widget should allow you to bind dynamically a link to it.
You could potentially try the value display widget as well, but I believe Image widget is the correct one.
6 REPLIES 6
PaiChung
22-Sapphire I
(To:Ziyad)
Ziyad
8-Gravel
(To:PaiChung)
Hello PaiChung
Thanks for your answer I actually tried your recommandation but the problem is that I don't find GetFileListingWithLinks service in generic services ? is it a service that exist already in thingworx by default like getdatatableentries for example ?
Also I want to know if I need to specify the path that exist in my disc computer or the path of repository ?
path : 'TPM.Repositoy/tpm.plb/PALES/PP_355/Images_Elements'
or path : C://ProgrameFiles.... which I don't find by the way
PaiChung
22-Sapphire I
(To:Ziyad)
Service exists on the FileRepository Thing/ThingTemplate
Ziyad
8-Gravel
(To:PaiChung)
Thanks for your indication, Actually I created a thing called PLB.images where I put test images that I will use ( (please find attachement below)
Now I'm trying to load the image that exists in my repository in order to get a useful link result, so I can do binding after but I'm getting strange error called :
Error executing service GetImageByElement. Message :: ReferenceError: "Thingworx" is not defined. - See Script Error Log for more details.
Could you please tell me how could I solve this issue, I'm working on this since few days but it doesn't work, and I also want to understand why.
PaiChung
22-Sapphire I
(To:Ziyad)
Looks like you are passing in Path incorrectly it should be a string so it needs quotes on each side of it.
Ziyad
8-Gravel
(To:PaiChung)
Yes Exactly it was a mistake, but although LoadImage service don't work properly so I just used if else conditions to return string each time and it works for me
Thanks for you support
