Hey
I'm new in thingworx, and I have a problem with displaying data on the label chart.
I have 3 data sources, first and second one are numbers and the third one is in percent. What I was trying to do is display this data on a label chart, first two of data source should be bars and the last one should be the line.
I try to do with dual Y axis but don't have a clue how to implement this correctly.
When i select dual Y axis mode this option is appear
So this represents data source from 1 to 3?
If someone can give ma a hint I'll be greatful.
thanks
Hi @Pawel2685.
Which version of ThingWorx are you running? There have been some changes in the 8.5 releases.
A tutorial exists that may be helpful for understanding the many different options available. If you review it and still have questions, please let us know.
--Sharon
Hi @Pawel2685.
--Sharon
