Displaying the country names on google map
sreddy-21
Dears ,
I wanted to point out the different places on google map.
am a newbie,
Please and kindly help  me how can i do it with an example
Hi Sruchan,
Please follow this to get your ans : How to set multiple marker in google Map in Mashup ?
For that you need to create a service and return parameter as a Info Table , In mashup add this service and bind it's result in to map.
Mayank
Hi Sruchan,
Mayank
thank you for the reply
Can you please tell me with an example locatIon with step by step procedure.
It would be a great help and good starting point for me to learn ..
i am following your source code, as shown in the screen shot
As it is not very straight forward I couldn't understand how to use it
Hello Mayank
I have tried this
1. i created a thing , declared a property called loc with location property
2. i created service
and created a infotable with the help of ur scource code as shown below
var params = {
  infoTableName : "InfoTable",
  dataShapeName : "DataShape"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(DataShape)
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
// location:LOCATION
var location = new Object();
location.latitude = 23.452;
location.longitude = 72.124;
location.elevation = 0;
location.units = "WGS84";
result.AddRow({location:location});
//location:LOCATION2
var location2 = new Object();
location2.latitude = 23.123;
location2.longitude = 72.456
location2.elevation = 0;
location2.units = "WGS84";
result.AddRow({location:location2});  // You can Add multiple marker using Add row.
But when i tried to test the service the output is empty
PaiChung
22-Sapphire I
(To:sreddy-21)
Did you set your Service Output to InfoTable and then I also advice you assign the Proper DataShape to it as well.
btw since this is a platform there are quite a few ways to accomplish this.
One thought is to have a Thing per country all based on the same ThingTemplate and then you can add other properties/meta data including the location
then you can use GetImplementingThingsWithData to get the Countries, their locations and other information to use all at once.
