I use docke toolbox in win 2008 server r2, start a default machine with ip 192.168.99.101.
I put the microservices.properties under E:\ThingWatcher, the content is:
results.destination.uri=results://192.168.99.101:8080/results/models
file.storage.path=/tmp
dataset.webservices.url=
dataset.app.id=
dataset.app.key=
and I run command
docker run -d -p 8080:8080 --name result-standalone -v //E/ThingWatcher/db:/tmp/ -v //E/ThingWatcher/microservices.properties:/maven/results-standalone.properties twxml/result-standalone:2.0 -jar maven/result-standalone-2.0-bin.jar server /maven/results-h2-file.yml
in the terminal, everything is OK, but when I try to access http://192.168.99.101:8080/results/models, it gives me nothing, but it is supposed to show something, right?
then I run command
docker run -d -p 8090:8080 --name training-standalone -v //E/ThingWatcher/microservices.properties:/maven/training-standalone.properties twxml/training-standalone:2.0.0
in the terminal, it will give me message like:
C:\Program Files\Docker Toolbox\docker.exe: Error response from daemon: oci runt
ime error: container_linux.go:262: starting container process caused "process_li
nux.go:339: container init caused \"rootfs_linux.go:57: mounting \\\"/E/ThingWat
cher/microservices.properties\\\" to rootfs \\\"/mnt/sda1/var/lib/docker/aufs/mn
t/9fe81874568f3c4761b309da30fefadfa19db5c958edacf34ceb49884cce7b09\\\" at \\\"/m
nt/sda1/var/lib/docker/aufs/mnt/9fe81874568f3c4761b309da30fefadfa19db5c958edacf3
4ceb49884cce7b09/maven/training-standalone.properties\\\" caused \\\"not a direc
tory\\\"\""
: Are you trying to mount a directory onto a file (or vice-versa)? Check if the
specified host path exists and is the expected type.
Does anyone know where went wrong? I just totally follow the official guide.
you may try referring to this write up Creating Thingworx 8.0 with Docker and Postgres on a single server for test purposes
Yes, core == foundation.
Hi Chris
There is currently an issue for deploying the training and results microservices as a docker container on Docker Toolbox.
See https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS266265 , the article document this and give some alternate option for deploying.
Kind regards
Christophe
For the record, the issue while deploying microservices on docker toolbox was due to some missing settings in toolbox shared folder.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS266265 has been updated with the required steps.
