I am using navigation control and with that if I specify the targetWindow as New or self, Mashup Load event is not getting fired I guess.
Because on Load I am calling few services, those are not getting called. But if I specify the targetWindow as Popup or modal popup it works fine.
What could be issue? How could I resolve it? Kindly reply ASAP, its bit urgent. Thanks
Hi Suraj,
Please do open a case at the PTC eSupport Portal (https://support.ptc.com/appserver/cs/portal/), so that we can track and quickly resolve your issue.
It is resolved now thanks :)
Hello, im currently facing the same issue and I'm using ThingWorx v7.
How has this been resolved? Am I doing something wrong?
And how it was resolved?
