Does anyone know where the "HelloWorld Extension Project" (Eclipse project) referred to in the ThingWorx Extension Developers guide v1.0.0.0 is located? http://support.ptc.com/WCMS/files/167136/en/Thingworx_Extension_Developers_Guide_v1.0.0.pdf
I'll be darned if i can find it. I can only see the HellowWorld simple widget extension in the 6.0 Extensions.
Ok, so now I know to look here for the 'real oil'...
http://support.ptc.com/cs/help/thingworx_hc/thingworx_6.0_hc/
It's a shame the search engine here doesn't index the actual ThingWorx support portal, as that would add a huge amount of value IMHO!
Ok, couldn't wait, so I went looking on the old twc.thingworx.com community site, which thankfully is still up, and found these files and documents here...
