Does thingworx support Certificate based Mutual Authentication?
esirohi
Does anyone have any idea regarding how to support mutual (client/server) authentication in thingworx?
To enable mutual authentication over SSL in JAVA, we generally set the method of authentication in the web.xml application deployment descriptor to CLIENT-CERT so that client authentication is enabled only for a specific resource controlled by the security constraint.
How can we achieve this in thingworx application?
paic
(To:esirohi)
Thingworx supports specific Certs for Server (with .pem on client) as well as specific Client cert.
If you use a client cert, I believe similar to what you've done, you need to adjust the Tomcat settings to accept the client cert.
