I'm currently dealing with a project in which I want to download the contents inside a grid in .exe format. I request for a solution.
Shahnaz
Thank you for your response,
Actually I needed the contents inside the grid to be download in .exe or .csv format.
I have figured out a solution by writing a service that returns the required Infotable and bonded it to the Data Export Widget.
Could you explain more what you want to achieve?
You want a grid with links to exe files?
Raluca Edu
Hi @shahnazkn.
If you are satisfied with the solution you found, please mark your last post as the Accepted Solution for the benefit of others on the community.
--Sharon
