Downloading grid columns header in excel
svisveswaraiya
Is it possible to download the grid columns header to a excel by clicking on a button?
Shalini V.
Hi @svisveswaraiya
It looks like you may have found the answer to this question via one of your other posts.  If you are satisfied with the response, please mark both posts with the Accepted Solution.
--Sharon
Hi @svisveswaraiya.
Take a look at the Data Export extension available from the PTC Marketplace.  The export won't contain the customized grid headers you set via the mashup, but it should contain the column headers from the data shape.
--Sharon
Hi slangley ,
Thanks for your response.
But the data export widget downloads the entire data rows. I just wanted to download the column headers alone without the data/rows. Is that possible with export widget?
Hi @svisveswaraiya
--Sharon
