Dropdown List Widget goes up instead of down
TricoSupport
7-Bedrock
In the past couple of days the behavior of my dropdown on a mashup changed from going down to going up.  It occurs on IE, Chrome, and Google.  I also moved it to multiple locations and created a new dropdown with the same information with the same results.  I hadn't modfied this mashup and it was working correctly.
Hi @TricoSupport is this the behaviour only on this particular mashup or does it permeates to other mashups as well ? how is the layout setup for it? Is it possible to share the mashup (by exporting it) with this entity for testing it out? Or may be if you have steps to reproduce could share that I can check that out for you.
Hi TricoSupport,
Just wanted to follow up to see if you were still experiencing this issue.  If not, please share with the Community how you were able to resolve.  If not, please let us know the current situation.
Thanks!
Leigh
