Time series chart v2 multiple y-Axis
fmanniti
Hello, I would like to plot two datasets on the same widget.
A) Goes from -20000 to +30000
B) Goes from 14 to 37.
Since I have the same Y-axis scale I only see A fluctuations since B curve looks like a straight line.
Is it possible to use a two scales using Time Series Chart V2 widget?
Thank you
Not with the marketplace one, you can only do this with the standard ones.
Carles.
dupatel
(To:fmanniti)
@fmanniti I believe at present we do not have feature to allow multiple Y axis scaling in single Time Series Chart.
-Durgesh
Carles.
Leigh
Emeritus
(To:fmanniti)
Hi @fmanniti
Wanted to follow up and see if you question was answered.   If so, please mark as Accepted Solution for the benefit of the rest of our Community. If not, let us know the current situation.
Thanks!
Leigh
fmanniti
(To:Leigh)
Unfortunatelly there is no solution at the moment. You must use the default version as @CarlesColl suggested
